LOL!Consign it to history, relevant learning is all on YouTube [and the manual if you look hard enough and can read]
Take care out in the wide world fellas![]()
Lightwave learning has been under heavy decline on youtube for quite some time, it doesn´t cover all the articles of insight and help that has been put up here on the forums for years.Consign it to history, relevant learning is all on YouTube [and the manual if you look hard enough and can read]
Not much changed in latest Lightwave from Lightwave 8 the rigging system is the same, maybe Gnoma was added in 10 and in 2018 PBR render and OpenVDB stuff that don't have any effect on rigging tutorials.Consign it to history, relevant learning is all on YouTube [and the manual if you look hard enough and can read]
Lightwave on youtube is bad currently, should be better really.I would hope that they would definitely archive this forum if unable to continue it because there is a depth of knowledge here in this forum that you can't really find anywhere else. But I do think there are several YouTube channels that are doing the best they can to keep things current. Some channels, like Bryan Phillips and Mark Warner, are particularly advanced.
I had hoped that it would be possible to transfer the LW content on this forum to the new owners to incorporate into new forums they would host. I can tell you now, however, that this is all evidently quite difficult to achieve, and instead what will happen is much as you suspected. There is no intention to remove or hide this content here (at least in the near term) as it is obviously a treasure trove of useful knowledge (along with a fair bit of good humor and some tragedies, too). However, on or about the end of this month, the LW-related areas here will be marked read-only.I would hope that they would definitely archive this forum if unable to continue it because there is a depth of knowledge here in this forum that you can't really find anywhere else.
But, but...I had much the same thought, but am told the amount of data involved is so huge as to make that quite challenging.
how much data? More than 8tb?I had much the same thought, but am told the amount of data involved is so huge as to make that quite challenging.
You shouldn´t have posted so much
Yes, of course, all those points I have..blah, but you know..this is where you should study...
