Hi,
Since the last update , I've a lost connection between VMC and Surface.
The serial module is reachable and at the start of session , everything goes well .
There is an update , or a setting to avoid that disconnection.
how can I put also the table in a VLAN, by now , I use the 2 connections 10 Gbe ( 1 normal lan , 2nd on VLAN dedicated for I/O Connect.
no reconnection appears when disconnect.
Which mapping must I use also for this surface ? Gemini or Geminijr ?
The web server serial on USR module connect , but no info when buttons are pushed.
thanks .
thanks .
