Thanks fashion, I will look in to that book.
Of course the form principles are valid for digital artists, there is no difference in coordinates of the form other than it is just described in digital form in the digital world, the real world coordinates can be described digital and the digital coordinates has it´s represention in the real world
I always loved sculpt modeling with clay in school, up til high school, and many years ago a little hobby clay and plaster casting, but not really in depth to the level that I could call me a sculptor, neither hobby or proffessional.
I did however scare the sh..t out of a woman around 1992 at work, when I made a fetus, not unlike my avatar, in cernit clay, cooked harden it in the oven or if I boiled it, can´t recall now, then painted it with some oil colors, so with that white cernit surface and thin pink, red oil to it, it kind of started to look like a real fetus.
I took it to work to showcase a few guys, then put it in the drawer, then another female collegue opened it and saw that fetus there, and not only that..she previously had a miscarriage.
Apart from school lessons, I haven´t done my homework more than buying Lous slobodkins book about sculpting, though that book was lent out and somehow is lost now.
It´s fun to start with small clay figurines in plasteline(plastellina) you can always test some plaster casting on it.
It is responding nicely when carving and pushing, smearing it, depending on how much you make it warm in your hands, for basic appliance build up, you warm it up, to carv fine details and adjust push, you let it cool down ..which it automaticly do after a while if you do not squeeze it, and it maintain the form you give it, there are other hobby clay that sort of doesn´t.
making the final cast from the plaster mold, you could brush paint cover th plaster pores with ordinary green soup on the inside of the first mold which is the negative part, that seals the pores of the mold, then a bit vaseline, very thin, then you can poor additional plaster in that which gives the final cast, then you start to hack away on that till the final product is there, a bit of work to seal it all and make an opening to pour it all in though.
Or use the same dentist material and what makeup artist mostly used for the mold. ..Alignat, which will give you extreme detail.
I have supersculpey to try out..been lying here for many years though.
