1) compile to 64 bit if it has to run on LW 2018+ as Denis pointed out. LW <=2015.3 has 32 bit version.
2) compile to dynamic library!
3) export server description (check source\serv.def file). It might have different number of underscores depending on compiler though.
4) compile in such a way that none external dynamic library will be needed (e.g. in MS Visual default is Runtime Library > Multi-threaded DLL.. so if somebody has no the right library at search path, won't run executable made with this option turned on).
