lardbros
Not so newbie member
Hey there,
I've just sent a scene from LW to ScreamerNet (using the Backburner Plugin available on these forums), and the resulting files are rendered out without any colour space settings.
Has anyone else found this?
Does anyone have a fix?
I ended up just rendering the RGB diffuse out using the standard Output options, and used the Compositing Export Buffer to handle the Shadow output and reflection... but this is NOT ideal.
Newtek, is this a known bug or problem?
I realise most people want floating point image formats for compositing... but for a quick job like this one, I just wanted standard output to PNG, and a quick comp... but would obviously need them to all be in the same colour space as the RGB output from the normal panel.
I tested doing an F9 using the file on my local machine, and the files were correct, so it appears it's an issue with sending it to ScreamerNet!
Thanks everyone for any help!!!
Tim
Tim
