I'm a bit new to Lightwave Layout, is there a simple or easy way to save poses for my character for later use? Im running LW 2020 on a Mac running High Sierra
You could try Legato.
I don't know about Mac compatibility but it handles Poses and Animations.
From the same Layout timeline, or from an external LWS file that has the Legato plugin applied.
http://home.kpn.nl/vincentmesman/legato.html
First you must identify each pose and/or animation by defining markers and/or regions.
After that you're able to Clone, Move, TimeStretch, Bake, etc.
You may add each marker or region to the Library, in the negative frame range.
Select a frame range, then, MMB-drag to Clone, RMB-drag to Move a pose/animation.
Or select a target frame (range), select a marker or region from the listbox, then
press button 'T' to Transfer a pose/animation.
Note: LScript support has been stopped after LW2020.
Anno 2020 it's still a Work In Progress but many features should still work surprisingly well (at least on my PC).
