Hi daforum,
I am not sure if I understand you right.
Do you mean each script of the bundle separat? Yes, they do, if they are installed right. Each part of the bundle works for its own. They share only a path for input and Output and help.
Or do you mean if the scripts run without LW? No, they do not.
If you want for example only some scripts, than you can delete all other scripts (*.ls) and their corresponding help files and graphics. But why not installing all? Is it because of the disk space they need?
If this is the reason and you can work without help, than you can delete the help-folder of the nuArchitect-bundle iclusive the subfolders in it.
If this is not the reason, than describe what is the reason for your question.
Regards,
KANUSO
