Not sure if you have to try and run lightwave as an administrator or not when installing the license, I recall there was some issue with that, so try that, or if that is what you do, then don´tThe licenses used to work of course. And when I drag them on the window again, it just says they were installed and to restart. But it restarts in discovery mode.
Yeah I got the right licenses. Now I have another issue. It won't even download any zip files of the installer from the account page. I've turned every security/firewall off and tried 3 different browsers. It fails to download zip files!You probably know all about his since before, but in any case it could help, make sure you have the right license key downloaded from your account, matching the versions you are applying them to in the first place.
I timestamped it at the license setup..
Could be your browser, I tested with chrome right now, no need to change http to https over here, and right click to download the licensing works without any need to bypass warnings,Weird.... I had to change the http:// to https:// on the download link, and then bypass the warnings to download the installer.
Did you now run it with admin rights as I said in post 4?Finally managed to re install fresh and now the license works! I guess I'll never know what caused the issue.
For LightWave 3D Users:
- Download the license file first, you cannot drag and drop directly from the webpage
- To avoid license key problems under Windows, run the installer with Admin rights
- Existing owners can also use their hardware dongle for plugins that are still tied to it
- The new software based licensing is only available for LightWave version 11.0.3 and higher
- Drag and drop activation is available in LightWave 11.0.3 and higher
Yes I did. thanks for the tip.Did you now run it with admin rights as I said in post 4?
It is also described in the license install help files..
Glad it´s working, most likely that was the cause.Yes I did. thanks for the tip.
I am having SAME problem. I will uninstall and then reinstall and hope it's the FIX. THANK YOU for this thread.Finally managed to re install fresh and now the license works! I guess I'll never know what caused the issue.
I can called LW I have emailed LW 3 times ...
