serket
another request for ye most esteemed, respected and wise toaster elders -
am looking to get a simple mirror style DVE that would be similar to the mirror effect built in to many camcorders (mirroring from the center of the image) - if this already exists, pointing me in the right direction would be very much appreciated, and if it doesn't exist, does anyone know how it could be created?
ideally it would be similar to these two DVE's :
UpperToLowerEdge.dve
LeftToRightEdge.dve
except it would use the same signal in main and preview, mirrored horizontally or vertically - it seems like it could be somewhat straightforward, since this is already partly achieved in FlyAwayBoxLeft.dve
perfection would be a set of DVE's just like the two mentioned, that mirrored the picture progressively as the transition moved, so the mirrored portion could vary - from side to side or upper to lower
any help or feedback on this whatsoever would be awesome - thank you in advance!
LeftToRightEdge.dve
