OD Substance Reader --> works for me (LW 2020.0, Win10 Enterprise 1809)...
- OD Substance Reader --> seems not to work but maybe an issue on my end - can someone confirm? (see screenshot below)
- OD Tools 2015/2018/2019 --> too many to be tested, but some I tested do work
- 3rd Powers PaintWeights --> doesn't work, weight paint is immediately lost when releasing the mouse
Many thanks for the link. I will have to investigate this later. With Mambo/DarkChief still only running LW2018, compatibility with the latest version of LW has been a concern.Might be of interest: https://youtu.be/Ft5OEd1PYaw - by Mambo/DarkChief himself
So I started testing plugins for LW2020...
Many plugin are broken, also there seem to be some changes with Codepages, there are encoding errors.
Maybe this thread could be used to post plugin updates (which ones work over time).
TFD build 1427 works on Mac and renders, but as pointed out in another thread, lights have no effect on the smoke shader, with Fire off.
My previous tests with StarPro 2.2 indicated it worked.
It did in an empty scene.
If I try to add it with an object......not working
View attachment 147469View attachment 147470
The other bizarre thing is VPR shows render ok (starpro doesn't show, never has), but render shows ship barely visible......?
Thanks guys!
I guess it will take a while for some plugins to be compatible, but that's not different for new versions of other apps.
Hopefully Rebel Hill and Jawset will provide updates. Weird about PaintWeights, works well on 2019 but not 2020 for me yet, but I will now create a separate 3rdparty2020 folder for the new LW version.
TFD 1.0 Build 1439 appears in GL viewport but VPR does not start and any attempt to render crashes layout.
Jascha is informed.
So let's hope for the best.
Regards
Marcus
