Puguglybonehead
I've never had trouble with 9.6 as far as stability goes, until my current setup. (had no trouble with any versions of Lightwave, going back to 8.3 when I first purchased a seat) I've run 9.6 UB mostly trouble-free on a G4 and a G5 in older OS's (as well as running the last PPC-specific version) and I've had no problem with 9.6 UB on Core2Duo machines and even my MacBook Air (mid-2011, Core i5) running Mavericks seems to have no problem with it.
I don't get what's wrong. I'm running the final version of 9.6 UB on a late 2011 iMac (Core i3) and it's giving me all kinds of grief. When I try to load an object in Modeler from the file requester it quits. I have to click on a .lwo file in the Finder to get it to load. When I try to load a scene file in Layout from the file requester it quits. I have to load scene files using the Items/Load menu buttons. Saving files is another issue. Modeler will only save without crashing if I use Save Incremental. Layout is hit and miss with saving. If I try to load an image to use as a background image, it crashes. I have to load it into the Image Editor first in order to prevent a crash. There are all sorts of other little everyday operations that you normally take for granted that just aren't working right now.
This is driving me crazy. This is what it felt like trying to use ElectricImage Modeler way back in the day. Do everything 'just so' or else it'll crash or freeze or whatever. What could be wrong here? Why did 9.6 UB work just fine on a G4, a G5, a Core2Duo and a Core i5 running Mavericks but it won't work for me now? I can't handle going back to the tiny 11" screen and miniscule RAM of my MacBook Air. I can't afford to upgrade, either Lightwave or a newer computer at the moment. I am stuck with this 2011 iMac Core i3 for the near future at least, due to financial reasons.
Could it be the way I have my file system set up right now? I'll admit to being sloppy here. I don't have my Objects/Scenes/Images/etc in the same folder as Lightwave at the moment. I've got them in a couple of different folders in Documents. Now, I do remember when I first installed Lightwave 8.3. Everything installed into the Lightwave application folder. The entire directory was in there. (we're talking the G4 and G5 days here) Is this a directory issue? Do I need to place all my project directories into the Lightwave application folder again in order to get things working in a stable manner again?
