Gorbag
Geist im Maschine
I don't know if anybody might find this useful, but I've put up an LScript-to-Python converter web page. It can be found there:
http://www.bobhood.net:21134/
Enter a script name, and paste your valid LScript code into it, and it will be run through a Python backend that will attempt to convert it into a LightWave Python plug-in.
This is by no means a perfect converter. It simply attempts to get your LScript as near as possible to a usable LightWave Python plug-in. You are going to have to do further work to get it all the way.
Bear in mind some points:
- Some LScript code will cause the converter to fail.
- I will continue to work on the converter if/as I have time, but this is provided simply as courtesy.
- If your script is successfully processed, it is not retained. If it fails for some reason, a copy is cached on the server so that I can use it to identify/correct issues with the converter. If you'd rather not have your code retained for this reason, please do not use the converter. If you're conversion has failed and you do not want a copy of your code cached, please let me know the name of the script you used in your conversion attempt, and I will delete it.
- This is not officially supported or sanctioned by NewTek. I wrote this as a courtesy to LScript users, and I alone am responsible for it. That said, I am not responsible for damages, perceived or real, that result from your use of this converter.
