Yeah, you do. I like this feature request. I guess it would be similar to how lights are added in Layout.
B
I will try and manage that.
I can not properly script code either, need to learn that and in python as well, I can do lscript hacks though, which I did for getting modeler text tool in to layout, by actually editing the original script.
And with ls commander..you can apply the workflow as you say with Lights, like adding star lights, wich already has lensflares setup with star filter, you can probably make variations on that, I just tested so that should work.
But I think I tried lsCommander for applying a null with primitive types already setup like vdb containers etc, but it doesn´t work with only lsCommander..not when you change primitive types like that and trying to have that followed in the lsCommander.
- - - Updated - - -
B
Giving up on editing the forum hangups and double posts because of that, I will leave it as it is, thus anyone subscribing will also get double posts in their mail.
Forum fix please.
As for adding lscript, same with lights if you try and use lsCommander, you can add a light, make it have a lensflare..and even a certain kind of star filter, but you can not change light type, it will add a distant light, even if you add a point light when using lsCommander, so it is as expected with lsCommander, not all properties will work.
