I have 4 PCs: MacbookPro (192.168.68.109), Windows PC (192.168.68.111), Linux PC A (Ubuntu 20) (192.168.68.120) and Linux PC B (Ubuntu 22) (192.168.68.121) on the same network. Have installed the SDK on all 4. When I start a video stream on any of the 4 machines using the the SDK examples (say NDIlib_Send_Video_Async), the SDK examples and NDI tools (including https://github.com/keijiro/Nsm) can find the source in the remaining 3 machines. However, only Linux PC B is unable to send/receive the frames to/from the other machines. Sending and receiving on the same Linux PC B works as expected. While the other three machines can send/receive video frames to each other. How do I go about debugging this issue? Is it a network/firewall issue? It is critical for me stream from Linux PC B.
FYI...
On PC B, when I run NDIlib_Send_Video_Async, this is what I see using netstat.
Btw, I didn't set up the Linux PC B and am not entirely sure if any firewalls or rules are blocking the tranmission/receipt .
FYI...
Code:
$ netstat -tlp
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 localhost:38021 0.0.0.0:* LISTEN 13377/Code --standa
tcp 0 0 localhost:36587 0.0.0.0:* LISTEN 13367/Code --standa
tcp 0 0 localhost:domain 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:5960 0.0.0.0:* LISTEN 70417/./NDIlib_Send
tcp 0 0 0.0.0.0:5961 0.0.0.0:* LISTEN 70417/./NDIlib_Send
tcp 0 0 0.0.0.0:ssh 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:http 0.0.0.0:* LISTEN -
tcp 0 0 localhost:ipp 0.0.0.0:* LISTEN -
tcp6 0 0 ip6-localhost:ipp [::]:* LISTEN -
tcp6 0 0 [::]:ssh [::]:* LISTEN -
