DP Web
-DP Web is a Light plugin which takes photometric data of a luminary stored in a
IES, EULUMDAT or CIBSE industry-standard file, to simulate a physical light,
by reproducing the luminous distribution of the luminary.
-A lot of lighting data can be freely downloaded on Light Manufacturer sites,
with some other descriptions of the luminaries.
-Compatible with all IES type file: A, B or most currently C.
IESNA (IES format): "Standard File Format for Electronic Transfer of Photometric
Data and Related Information".
EULUMDAT (LDT format): "European Data Format for Exchange of Luminaire Data".
CIBSE (TMS format): "Standard File Format for the Electronic Transfer of Luminaire
Photometric Data".
'ERCO 1xQT12-ax_50W' 3D model + IES web. |
-The Light Emitter is the light shape, could be a single point if dimensions are null
or a 2D/3D shape, illuminated and photons samples are emitted from this shape except
if samples number is set to 0 or 1, in this case even Light shapes are evaluated
as point emitter.
-In some files (see CIBSE note) the luminary dimensions are used instead of the true
luminous opening shape which should be generaly smaller, but the regular scaling
layout tool can be used to rescale of the light to something around 80%, depends
of the luminary description. -The light illumination decay follows the physical light's inverse-square falloff law.
-The current regular LW Light Intensity is used as an intensity multiplier.
-Since Lamp Color is optionaly defined in luminary files, the light color must be
input by user.
-The Light Color can be the regular LW Light Color or a Color Temperature from a
Lamp List or a Kelvin input, the kelvin color conversion is related to the Indoor/Outdoor
Kelvin reference.
This Color is always multiplied by LW Color, so for pure Color Temperature,
LW Color should be white, or it will alterate the result like a colored cellophane.
Photometric with rectangle or disk luminous shape are often Y oriented, it can be
re-oriented in the Z+ Direction, for correct Motion Targeting.
In case of double sided shape, the face with the max intensity is aligned to Z+.
