Markc
ack ack
I have painted an object in 3D Coat with metallic materials and some Matt painted areas.
Initially just exporting the textures and applying to a Conductor node in LW, everything is metallic.
So I did the Matt paint on a separate layer in 3D Coat.
I setup the paint material to a BSDF node in LW.
If I use the material mixer, the only option is an alpha level which affects both materials and so makes the metal surfaces lighter.
Is there a different node to achieve this (metal object with Matt paint)
