Ma3rk
Curmudgeon in Training
Continuing with my water theme I guess, this definite W.I.P. is actually several accidental revisits of sorts. The architectural element is my first or second exporting dabble (more to come), so between trying to translate "that which is Daz w/o docs" (TWIDWO), and the changes, quirks, etc. with LW over the same time period, (no acronym, just fact) it was all pretty much a moving target. Now let's throw in COVID and having to return to LA twice just to make sure I'm utterly befuddled, 'K?
After a LOT of Trial & Error, & finally winnowing the chaff, I got a pretty good workflow now. For example, when a surface says it's glass (you always check), but the geometry isn't correct for dielectric glass, it's an easy fix. Other geometry issues w/ older models, morph exports, PBR surfacing, etc. really vary by artist so not entirely under Daz's control; they're just horrible at QC.
But this current revisit all started with the little guy in the bowl.
I've had him ~ 8 mo., but haven't been able to export him with his morphs. I've exported hundreds of models in FBX with their morphs w/o problems. Tried to find out why. TWIDWO. The short version of this is that the Daz forums were zero (or less) help.
But while waiting, I recalled a utility I purchased years ago that I never really tried other than kicking the tires to make sure it worked. After a few "almosts", got it working in conjunction with "Bg to Morph" in Modeler. Need to figure out how to streamline or script the process perhaps, but this is really the first time I've need to do this sort of thing.
OK, so now got him working but need a place to put him to show him off. After three other false starts, I decided that it's not just Goldy (as Cleo), but I needed a full environment to reflect & refract in that bowl, which itself turns out to be a character. I've a number of interior sets, but few suitable.
So I went with the "FG Moderno Casa" by Fugazi1968, aka "Casa Fugazi", and as I said one of my earliest purchases and export to LW efforts, so seeing oodles of mistakes compared to what I currently use.
And sort of like Ripley to Newt, "Oh, oh. Now I made a clean spot", (you can correct me on the exact quote, Prom), it started getting out of hand, but in a good way. Never knew why or where I'd use a pose like that for Tux Cat (as Figaro), but here it was fitting & had a cat once that would do just that!
Had to kick samples up to 9's & 5's for all the glass & water. Probably spent 2-3 tracking that down some time back, in conjunction to having the HDR vis to camera. Makes sense in hindsight, but the kind of "rub your tummy, ..." etc. stuff that I hope gets addressed by the new team.
As a side note, I hope one of the hidden benefits the LW transition to Lightwave Digital, is that those we haven't heard from it some time, most likely gagged by NDA's, can and want to speak here again. I was a regular attendee of the LA LWUG in Burbank and I miss having that access, and with that gone on the forum as well ...
