Xpanel envelopes
darkChief
I'm having trouble accessing envelopes. Using an interface outside a handler. All the envelope examples are used inside a handler.
When I use LWXP_FORM (with an envelope control) the panel crashe's lw. If I use LWXP_VIEW with the set and get functions the controls are disabled. The get and set controls never get called.
creacon
creacon
I remember having the same problem, I'll look it up.
creacon
creacon
I'll have to check tomorrow, what I can tell you already is that I am using an LWXP_VIEW, the Callbacks get called and I am using envelopes.
creacon
creacon
creacon
I don't understand what you're asking. All plugins are handlers. An Xpanel is the UI (or part of the UI) of these handlers.
Can you explain where (outside of a plugin) you would want to use a UI?
creacon
Thanks. Can you use them outside a handler?
darkChief
I don't like putting my ui codes in handlers because I use singletons to centralise my code. So I rarely use userdata.
My ui code goes into LayoutGeneric (not a handler right?), this has worked well in isolating frontend from backend.
So let me rephrase, can you them in LayoutGeneric?
creacon
creacon
Ah I see, it seems I have only used Handlers in my plugins.
How are you building your panel, by passing a hint?
darkChief
Okay got this working in a LayoutGeneric. I wasn't setting things up correctly. You can create your own channel group, no dependence on an item.
