X Symmetry Topology LScript - somebody knows?
OFF
pass:sword
Not so fast. Now try to go on the link from the website of LW-plugins and download this script (in zip archive). :)
OFF
pass:sword
Yes it's a good plugin but only for work on a small objects. Even 5000 polys model freeze it...
spherical
So? Contact NewTek or Tama. The page is there. Tama's filename may have a typo, so 404s. You try BatchBandSaw, for example, and it works.
Try this one instead: https://github.com/artstorm/fix-symmetry
or this by same author:
http://artstorm.net/plugins/symmxmirror/
or this one:
http://www.danielefederico.it/works/script/DF_RecoverSymm/script/DF_RecoverSimmetry.zip
or this:
http://kevman3d.blogspot.com/2013/12/free-lw-scripts-just-in-time-for.html
Sensei
Tool doing this task (finding symmetrical points) cannot be LScript/Python.
It must be C/C++ compiled plugin though.
Otherwise it will be completely unusable on something more complex.
1 mln points = 10^12 (1000 of billions) sqrt() operations..
100k points = 10^10 (10 billions) sqrt() operations..
OFF
pass:sword
or this one:
or this:
Thank you.
strange, should be there, can someone test the link? maybe it is broken for some reason.
I am able to download the zip file from your google drive URL. The zip file contains informational files about the Lscript LSC file... but no actual LSC file is included. This is odd, because the zip file tests fine - yet it's size is significantly greater than that of the files I see in it. Maybe it's because I'm using Linux to download and extract the zip?? I'll test on Windows when I get a chance.
ah!
had zipped a wrong folder. fixed now. thanks!
