Weft of impression style
lamerehic
I am trying to get the Weft of impression of a newpaper printed image on a render.
Like the halftone filter of After Effects of sapphire effect tool set
http://www.genarts.com/effects/sapphire#tabs-8
For the moment i get dots instead the shadow but i cant get the dots scaling and get more of less narrow with the lighting
If someone has a clue.
if you do not necessarily need a solution with nodes, you can use the "Halftone" shader (Surface Editor > Shaders tab).
ciao
Thomas
omichon
My advice : Try to start with the simplest node setup as possible.
Basically you want a texture to be driven by a shading node. Once you get the basic, feel free to fine tune it.
In this example I have used an IFW2 texture, but you can use any texture you want.
I also have used DPKit to orient the texture to the camera.
Hope it may help.
  • donut.mov
XswampyX
Active member
If you want to shade the whole render try the node image filter and the Dots procedural texture... Like so.
