want to reproduce LW11.6 shading!!
You might have some luck with the native Cel Shader in LW2018, but I don't know if it'll meet your needs. Here's a quick, low-res model (not matching Marty's head very well, but OK for demonstration purposes). Sample scene attached.
CelShading_MartyTheMonkey_LowRes_NativeCelShader_000.jpg CelShading_MartyTheMonkey_LowRes_NativeCelShader_098.jpg
MOV File: View attachment CelShading_MartyTheMonkey_LowRes_NativeCelShader.mov
and the wires of the model:
The setup is to turn OFF Global Illumination, use Standard materials, and have two separate Lights, one for Diffuse with a large Angle for soft edges and shadows and one for Specular with a zero angle for sharp edges on the eye specularity.
The Cel shader is in the Shading Model tab of each Surface. The "base color" in the Standard Surface panel should be pure White so the colors specified in the Diffuse gradient of the Cel shader will be shown accurately:
NOTE: you have to click the "+" on the Diffuse gradient TWICE to get the panel where you can change the keys. The small arrow in the upper right provides a Key panel (e.g. Select All, Erase, etc.). Why LWDG didn't use the already existing Gradient interface here, I don't know!
The Skin surface has Linear keys and widely-spread keys to have a very smooth transition between the colors as the Light incidence changes. The Nose and Hair surfaces have Stepped keys and the keys are more closely spaced to have harder bands in the transition.
Good luck!
mTp
  • CelShading_MartyTheMonkey_LowRes_NativeCelShader.zip
Ahhhh thank you!
Damn it it soo obvious to use a colored soft-gradient-cel on the skin... aaaaaaaaaand of course i totally missed it :D I was playing with incidence/gradients. My goal is to create a special kind of cel shading ( if there is any... :D ) anyway, with this and the extra gradients i think it will work well, but... we will see :D Bigbig thanx :)
ekho
Glad to help! Once the general environment is set up (Cel shading on the surfaces, separate Diffuse and Specular Lights, and a wide Angle on the Diffuse Light), then I prefer using the Incidence and Gradient nodes rather than the Cel shader's interface. Once you move into the node network, it provides MUCH more versatility in expanding the look of the shading.
It's the same concept of a soft, subtle transition unless you want harder bands:
An Item Info node is used to get the Diffuse Light's World Position, which is fed into the Incidence node. The Incidence node is set to 180 degrees, allowing an even darker shade on the opposite side of the geometry from the Light, although in this case I didn't use one. The Gradient node then provides the shading. On the Skin surface, there's an additional Scalar Layer node to add the UV Mapped image of the smile.
Have fun!
mTp
  • CelShading_MartyTheMonkey_LowRes_NodalSurfaces.zip
As I mentioned, by going nodally you can get substantially more control over the shading and drawing effect than the plain Cel shader. For example you can get a relatively good "hand drawn" cel shading effect. I don't think it's what you're after, but it's an interesting technique anyway:
MOV file: View attachment CelShading_MartyTheMonkey_LowRes_HandDrawn.mov
Here's the Skin surface setup, using Stepped bands in the Gradient to get something like hand tinting (Hair and Nose are basically the same):
The Geometry is "jittered" with a randomly jumping Turbulence Bump Layer on the Z Position:
The Silhouette and Sharp Creases Edges are enabled, and their Opacity and Taper are controlled with a combination of another randomly jumping Turbulence texture, the Light's Incidence, and the view's Incidence:
mTp
  • CelShading_MartyTheMonkey_LowRes_HandDrawn.zip
Thank you, MonroePoteet !
so sorry I haven't noticed your responses..my bad..
Using two separate Lights doesn't come to my mind at that moment.
It's great idea!
I happened to take a look at the tutorial video made by Japanese studio, Kmakikaze douga, and
found that they also use light in order to get nice shading results.
I hardly ever use multiple light in a scene before, but it's definitely worth a try.
anyway, thank you again, MonroePoteet for giving the right approach :)
A shame there's no English dubbed/subbed version of those. Oh well.
Does anyone have any idea of the full list of Japanese tutorials we are talking here ? They certainly know a thing or two about character animation so even watching a non English LW video for CA might pick up some additional tips.
Depends on whether you can overcome both Japanese narration and a Japanese-localized version of Lightwave, as is the case here.
If it were narration alone, I can see how that could be useful even for non-Japanese-speakers so long as they could still follow in English UI what the tutor was doing. However, without being able to understand the speaker, nor be able to read LW's UI, I think that presents a much more difficult situation (lacking any level of Japanese language skills). YMMV.
Since I don't get how nodes works yet, allow me to ask this...
How can I achieve this nice shading below in LW2018?
https://forums.newtek.com/showthread.php?136625-Marty-the-Monkey-LW-11-6-nodes&highlight=mity+monkey
I can't find any replacement for SSS node which is used in the shading...:confused:
This shading method gives me nice smooth shades even if models are very low-poly and that's why I stick to it.
corrected Link (1) Marty the Monkey + LW 11.6 nodes | NewTek Forums
Back
