Volume Transfer from A to B with open VDB
prometheus
REBORN
Render looking good there.
(y)
Not sure what kind of drink you mixed though, feels like some kind of weird pink juice :unsure:
Some special Rene brew I suspect, without alcohol.
LightWaveGuru
Active member
(y)
yes its more a heavy juice. but i can also show water or something like this....
btw
you see the default parameters of the solver concerning gravitation (9,81) etc.pp
if you change the values also the flow behavior changes.
as said.
fluids can look like this or like that depending on the intention of the simulation.
it is therefore sufficient to simulate with e.g. 60 instead of 30 fps and the results will be different.
finally, the best way to control the speed of the fluid is in the post.
to do this, you load the sim in open gl into the previewer and drag the fps there.
so you can already see in the preview with which speed the simulation will look most "real" when you play it later out.
so there are many ways to die. many ways! so its not for kids! LOL :)
snip LWGuru
