VMC1 IN/NC1 IN - Which network adapter???
frippe77
Hi.
We have an "old" VMC1 IN and have been testing it for a while.
From the start I noticed that there are two network connections and my question is: why?
Is one of the network adapters better than the other? I that case - which one to choose?
Best regards
/Frippe
kanep
NewTek SE
You use either. In fact, you can even use both and NDI will send video down both ports to give you the equivalent of 2 megabits of bandwidth on the unit.
frippe77
Hi Kane and thanx for the input.
When I have the option of choosing between a motherboard-based LAN-adapter (Intel) and an ”external” (Atheros in this case) my common sense often tells me that the external might be a better choice...
Interesting to use both ports simultaneously. Maybe we should give it a try...
/Frippe
