VMC own sources not visible?
Martin Brundin
We discovered that we cant see our own sources anymore since 7-3-200428. Only the active NDI router outputs + telepromter are visible. Anyone knows if there is a way to activate the other sources? (ddr, mix outputs...)
//Martin
If you rename the MIX outputs to someother other than MIX #, they will not appear back into the system.
Hi ,
I checked here, I have a similar problem. Actually I still have the MIX outs, but not the internal sources as before ( example, the 4 DDRs). Bug or new feature ?
Back
