Vista 64 bit
MarkSPatterson
Just curious if 3DA will work on a Vista 64 bit system? I have discovered that some of the other programs that I use will not so I have to upgrade. Should I wait for 2.0?
Verlon
I should update my Avatar
It worked on XP-64. Not sure why it would not work on Vista 64. It is NOT 64 bit capable unless you are using 64 bit lightwave and 3DA content disk, but it does run.
MarkSPatterson
64 bit
Thanks for the input. Lost my VT3 in a fire last year. Honing down to just what I need... just want to make sure everything will work on the new system.
