Useing transitions when switching camera angle in clip playback in 440
Simon3Play
Just wondering if there is a way to add transitions when changing camera angle within playback or shift + angle when replaying back clips?
kanep
NewTek SE
The SHIFT+ANGLE function is always a cut.
If you want this type of workflow, you would have to use both outputs and then operate the 3PLAY in Preview/Program type workflow, where the A output is Preview and the B output is Program. There is an AUTO button on the 3PLAY control surface to perform a transition between the two outputs.
Simon3Play
Thanks for the response. I am aware of A and B switching with AUTO and was just wondering if there was on option to change SHIFT + ANGLE from cut to a transition. Thanks again
