Typed the following query into "The New Bing" or Bing AI: "hide NDI trademark logo in OBS, Zoom and Teams"
Bing AI gave the following response:
"There are a few possible ways to hide the NDI trademark logo in OBS, Zoom and Teams, depending on the situation and the settings. Here are some suggestions:
- If you are using Zoom Rooms, you can disable the NDI feature from the Zoom web portal, which will prevent the NDI logo from appearing in the video window².
- If you are using Zoom Meetings, you can hide your profile picture in the meeting, which will replace the NDI logo with your initials or a generic avatar².
- If you are hosting a webinar in Zoom, you can customize the webinar branding settings, which will allow you to add your own logo or banner to the video window, covering the NDI logo².
- If you are using NDI Tools, you can try to update to the latest version or uninstall and reinstall the software, which may fix the issue of the NDI logo flashing or appearing solidly³.
- If you are live streaming the meeting in Zoom, you can add a live streaming watermark, which will overlay your own logo or image on the video window, hiding the NDI logo².
- If you are using Teams, you can enable or disable the NDI feature from the Teams settings or permissions menu, which will control whether the NDI logo appears or not⁴.
- If you are broadcasting the meeting in Teams, you can use NDI or SDI technology to send the audio and video streams to your local network, where you can use other tools to edit or remove the NDI logo⁴.
- If you are using OBS, you can use the NDI plugin to capture the NDI video and audio sources from Zoom or Teams, and then use the OBS filters or sources to hide or replace the NDI logo⁴.
- If you are using the NDI Webcam Input tool, which converts the NDI video stream into a virtual webcam feed, you can select the tool before you launch the Zoom Room or the meeting, and then choose the NDI Webcam Input as your camera source, which will hide the NDI logo¹.
Source: Conversation with Bing, 2/13/2023(1) Using Network Device Interface (NDI) – Zoom Support.
https://support.zoom.us/hc/en-us/articles/360061903532-Using-Network-Device-Interface-NDI- Accessed 2/13/2023.
(2) Unwelcome NDI trademark appearance in Zoom Meetings.
https://forums.newtek.com/threads/unwelcome-ndi-trademark-appearance-in-zoom-meetings.164905/ Accessed 2/13/2023.
(3) How To Broadcast Teams Meetings Like a Pro with NDI and OBS.
https://petri.com/how-to-broadcast-teams-meetings-like-a-pro-with-ndi-and-obs/ Accessed 2/13/2023.
(4) NDI in Zoom: Deep Dive - StreamGeeks.
https://streamgeeks.us/ndi-in-zoom-deep-dive/ Accessed 2/13/2023."
