TriCaster 40 Tech Specs
Status
Not open for further replies.
shepherd
Switcher Channels14 – 6 external, 4 internal, 4 virtual inputs
Video Input4 simultaneous live video sources, in any combination of HD Component, SD Component, Y/C or Composite and supported resolutions:
  • Each input includes integrated frame synchronizer
  • Independent keying, cropping, Proc Amp and white balance controls per input
  • BNC connectivity
Network Sources2 simultaneous live sources via Gigabit connection, selectable from any networked computer or Apple® AirPlay® device:
Media3 integrated digital media sources for video and graphics: DDR and GFX x 2:
  • LiveText character generator for custom titles and graphics
  • Independent keying, cropping, Proc Amp and white balance controls per source
Virtual Inputs4 independent, mix/effect-style channels supporting multi-source compositions, virtual sets, double-box effects and more:
  • 3 configurable sources per channel, each with independent positioning, scaling and cropping, including upstream keyer with DVE and transition controls
Downstream Key2 downstream keyers, each with independent DVE, transition controls, positioning and scaling
Video LayersUp to 5 layers on-screen simultaneously
Effects and TransitionsIntegrated TransWarp effects engine on all effects channels supports standard transitions, customizable animation store transitions with audio, and overlay effects:
  • Animation Store Creator for custom animations
  • Supports per-pixel alpha blending between sources and real-time 3D warping of video or graphics
Virtual Sets24 HD live virtual sets, with multiple camera angles, real-time reflections, specular highlights, animated zoom and presets
Video OutputA/V output signal through up to 5 output connections:
  • 2 x Analog BNC configurable for Component or Y/C + Composite (Program and SD-only AUX)
  • Network output for live streaming
RecordingNative recording in resolutions up to 1080p:
  • Record source selectable from among Program, Aux, or any individual camera input
  • Encoding format selectable from among QuickTime®, MPEG-2 (high or normal profile), AVI (Speed HQ), and H.264 (high or Web-quality)
Recording CapacityAccommodates ~ 20 hours 1080i or ~ 120 hours 480i via internal drive in QuickTime format:
  • Capacity expandable using external media drives
Live StreamingHD live streaming via Adobe® Flash® or Microsoft® Windows Media® Push/Pull
Audio Inputs1/4” Mono (Mic) RCA x 2 Stereo L/R (Line)
Audio OutputsRCA x 2 Stereo L/R 1/4” Stereo (phones)
Audio MixingIntegrated multi-channel audio mixer for internal and external audio sources, effects, output, stream and headphones
Supported FormatsNTSC model: 1080/30p, 1080/24p, 1080/60i, 720/60p, 720/30p, 720/24p, 480i (16:9), 480i (4:3)
Multi-Standard model: NTSC-J; PAL 1080p, 1080i, 720p, 576i (16:9), 576i (4:3) selections
Playback Media FormatsAVI, DV, DVCPro, DVCProHD, FLV, F4V, H.263, H.264, MOV, MKV, MJPEG, MPEG (1, 2, all profiles, program or transport streams), MP4, WMV, WebM, PSD, PNG, TGA, BMP, JPEG, EXR, RAW, TIF, AIFF, MP3, WAV, and more, with Import Media application for batch import with optional transcoding of files (including Apple ProRes)
Export Media FormatsExport media application for batch copying with optional transcoding of files to compatible formats for different applications and devices: AVI, DV, DVCPro, DVD, H.264, MOV, MPEG-2, MJPEG, MP4, WebM and more:
  • Presets for Non-Linear Editors: Adobe Premiere®, Apple® Final Cut Pro®, and more
  • Presets for mobile platforms: Android®, iPad®, iPhone®, iPod Touch® and more
MonitoringDVI and HDMI monitor outputs for user interface and multiview preview, with selectable layouts
Signal MonitoringIntegrated Waveform and Vectorscope, full field rate with color preview and support for ITU-R Rec. 601 and 709
ProcessingVideo: 4:4:4:4, 32-bit Floating Point
Audio: 2 channels, 96 kHz, 32-bit Floating Point
System Physical10.4 x 8.5 x 17.5 in (26.4 x 21.6 x 44.5 cm)
19 lbs (8.6 kg)
Status
