Talkshow Talkback Headset
Mike Tech
Does anyone know if it is possible to use a USB headset with Talkshow for the Skype TalkBack function?
Mike
PIZAZZ
NewTek System Integrator
Not sure right now but I do believe you can use Dante audio inputs to do that so it would make sense that a USB headset would work. It would be Monday before I could try it.
kanep
NewTek SE
If I recall, the Talkback feature is set to use the Windows default audio device. NewTek only supports using the built in audio card, so if you call into support this is what they would troubleshoot with. If you want to try setting your default audio device to the USB headset, you can see what happens. If it doesn't work, you will have to set it back to the built in audio card.
rlsafran
I have a Plantronics USB headset working just fine after I set the it as the default in Sound -> Record and Playback.
