Stream over Wifi?
TannerM
Hi there,
I'm interested in streaming from my mini 4k to a computer both hard wired to the network switch and connected to wifi. For some reason, the computer can recognize the NDI channels but can't bring up a video signal without internet wired into the switch.
Has anyone streamed over wifi? If so, do you have any suggestions?
Thank you!
boyler
I agree with DLVid, but I also recommend you use a WiFi enabled NDI Spark to accomplish this. It sounds like you need something with the HX compression to stream successfully over WiFi.
boyler
Yes - using the Spark as a source to send out the NDI signal. The WiFi Spark compresses using the HX compression to stream better over wifi.
