Some small annoying issues
yuriki
1. No way to set scale of the model in import or export dialog.
2. No option to change FPS after cache was imported (number of cache frames still the same after changing FPS).
3. Data loss in zero and first frame of cache (xml cache from Maya).
4. No option to import PC2 format.
5. Objects jumps to default position before cache start and after cache end (I must use pin tool at the end)
6. Crash each time I try to load project (dump attached)
  • LightWave_766d9e054619.7z
yuriki
7. Not working Enter on NumPad
8. No option to change colors for different objects and wireframes
9. No presets for Clip Properties. I want curves Ease In and Out be the same (as I draw them last time) at each time I add corrections by brush.
