Skype TX Control API
secondstar
Hello,
Where I can obtain the API documentation for Skype TX Control? The TalkShow's user manual have the reference to this document in appropriate section, but I can't find it.
Thanks!
kanep
NewTek SE
Are you talking about getting Skype TX Control and TalkShow working together?
Usually the most common issue is that you have 'Require Control Security' turned on, try unchecking this option and see if works.
Lawrence Berger
Where is this setting?
Have you ever tried to connect the return for two talkshows on the network. Using tricaster mini tricaster only allows on talkshow to use the return.
kanep
NewTek SE
The 'Require Control Security' setting is found in the gear in the upper left corner of the TalkShow. Go to the third icon (Accounts) and you will find the checkbox at the bottom.
AirSend (network protocol) supports one destination system at a time. When NDI is released in TriCaster Advanced Edition, you will be able to have multiple TalkShows access the same Network output feed.
SBowie
'the write stuff'
Staff member
Don't overlook the fact that the network return option is not the only way to connect a return signal.
Lawrence Berger
today I use a HDMI to SDI + splitter It would be so much simpler if Tricaster mini could return to more then one talkshow on the network. I have heard that a new advanced update is in the works to fix this problem.
SBowie
'the write stuff'
Staff member
Airsend, which is what all current TriCasters use for network connectivity, has always been limited to a single connection. NDI, coming this quarter, supports multiple connections.
