Shockwave exporter
Mbauer
What happened to the shockwave exporter? I can't seem to find it anywhere.
I am using Lightwave v8.3 on a MAC os 10.4.11
If I view my plugins I can find the shockwave exporter under LayoutCommand>Shockwave3D_Export
But I can't seem to find how to use it or engage it. It use to be under File>export but it's not there nor anywhere else that I can find.
Thanks for any help and sorry if this has been answered in another thread, I searched and couldn't find an answer.
MB
Mbauer
oops stewpid me
I forgot you had to do this:
Lightwave FAQs" said:
1. Goto the Utilities Menu.
2. Under Plugins select Edit Plugins.
3. Once the Edit Plugins Menu Comes up select Scan Directory.
4.Use the Browse for folder to select the Plugins folder in the LightWave Directory.
In Windows the default path is C:program FilesLightWave [8]Plugins
On OS X the default path is Hard Drive:Applications:LightWave [8]:plugins
Once you have the folder hit ok. For the Mac users hit choose.
5.There will be a pop up that says Add Plugins hit Ok.
6.Go ahead and hit scan directory again.
5.Use the Browse for folder to select the Legacy Plugins folder in the LightWave Directory. In Windows the default path is C:program FilesLightWave [8]Legacy Plugins On OS X the default path is Hard Drive:Applications:LightWave [8]:Legacy Plugins
7. Once you have the folder hit ok. For the Mac users hit choose.
8.There will be another pop up saying Add Plugins hit ok.
9.Close the Edit Plugins by hitting done.
10.Now goto Edit and choose Edit Menu Layout (PC Shortcut is Alt+F10)(Mac Shortcut is Option+F10)
11.Under Presets choose Default.(If this option is grayed out select 7.0 Style then go back and select Default).
12.Once you have chosen Default hit Done.
13.Close LightWave or Modeler.
14.Open LightWave or Modeler you will now have all the buttons and plugins.
All better now
