Setting an IP address for a Control Panel on isolated network
mattlewist9t9
We're just setting up our new studio...
Our new Netgear S3300 switch is on an isolated network. Is it possible to set an IP address for the 2-stripe control panel to enable it to communicate with our VMC1 without a built-in DHCP server?
We also have the same issue for our other NDI devices (12x PC workstations, 1x panasonic 4k PTZ, 2x I/O modules)
thanks in advance
kanep
NewTek SE
DHCP is not required for NDI (but it does make things easier!)
For the computer devices, just put in a static address and you will be good.
For the control surface, you should speak with customer support to go over what needs to be done. http://new.tk/support
