SDK example not functioning properly since V2
Doggy
Since V2 one of the C# examples,"managed NDI send" , only sends a frame every 10 seconds once connected locally.
The same example did not have any problems in V1 as do the other examples
Anyone has any idea or experienced this too ?
Thank you
Doggy
It does run BUT :hey:
it needs to be opened by 2 two receivers (monitors) to be triggered to run !!
Are you having any issue with the managed receiver example? We can't get it to recognize that NDI feeds are present on the version 2 examples.
Doggy
I can now after I changed "IntPtr SourcesPtr = NDI.Find.NDIlib_find_get_sources(_findInstancePtr, ref NumSources, 0);" in line 125 (approx) to
Code:
IntPtr SourcesPtr = NDI.Find.NDIlib_find_get_current_sources(_findInstancePtr, ref NumSources);
as NDIlib_find_get_sources is obsolete. did confuse me to initially
"managed NDI send" still has the issue (need to open 2 viewers to get it triggered to run sending)
ACross
NewTek Engineering
Code:
We have fixed this (I think!) in the next SDK release which should occur in the next few days. If you need it before then, just email [email protected].
We are not making the find_get_sources call obsolete, we are simply depreciating it (it will still work) and replacing it with two that should be easier to understand.
1) Let me know when changes to the list of sources occur.
2) Give me the current list of sources.
This was the API call that caused 90% of all email questions, so improving it hopefully will help.
Andrew
zenvideo.co.uk
That definitely sounds like a better mechanism.
