Rotate instances around centre of object using texture
stib
can't.. re.. member
I have a sphere with instanced objects around it, and I want to create the effect of a wave traveling along the surface by having the instances move around the centre of the sphere, along the lines of latitude, so to speak, meaning that the instances at the north and south pole don't move.
So the offset will follow a circular path on the x/z plane, and the magnitude of the offset is controlled by a texture. But the instances will stay the same distance from the centre of the sphere, so they never leave the sphere's surface.
Is thsi do-able with nodes? I've tried all the maths I can remember from high school, but I can't get it to work. What I can't work out is what the frame of reference for the offset is for each instance. Is it in world co-ordinates or relative to the normal of the base position on the sphere?
stib
can't.. re.. member
Kind of, except that the instances move around the surface. I kludged it by making a morph of the base object rotated around its Y axis a bit. It only works for rotations up to about 15º, but in this case it's sufficient.
