Reading NDI Stream in Final Cut Pro
sdan1976
What's the easiest way to get at NDI stream recording with the SHQ2 codec into FCP. VLC can display the video. Is there some software for the Mac that can convert the recording to ProRes?
sdan1976
It looks like the easiest way that I've found is to run it through Media Encoder. I've used Media Encoder to convert it to a ProRes 422 mxf file. Handbrake can also convert it to mp4.
Either Compressor or Adobe Media Encoder will do it
Compressor will not read the file.
kanep
NewTek SE
Install NDI Tools on the Premiere system which will install the NDI codecs for Adobe, this will allow you to read the native recordings in Premiere, After Effects and Media Encoder.
