Partigon relative particle age?
Triodin
Trying both DP Kit's Particle Info node and the ParticleInfo node to try and use a partigon's relative age to drive the animation of surface settings. Any thoughts on what I'm doing wrong?
dpont
..No can see why it doesn't work with this screenshot,
I added an emitter and launch particle2partigon,
in partigon's surface,
added a DPKit Particle Info node,
(native node does'nt work in this context)
no change in settings,
a Gradient node set between 0 and a few seconds,
connected the Rel. Age to Input
and got varied colors on partigons.
Denis.
Triodin
Monsieur Pontonnier!
I thank you for your help!
You have helped me look deeper at the Particle Info node - where I discovered to double click and select the emitter!
It worked perfectly. Thank you so much for your amazing plugins! Merci beaucoup!
