nuArchitect bundle V4 released
KANUSO
Hi together,
the release V4.0 of the nuArchitect bundle is now released. It is as so as the old nuArchitect bundle released as donationware. You will find the license in the nuArchitectV4LS.zip.
You do not have to donate, to use this scripts, but it would be fine and would Support me in creating more of that stuff. If you want to donate, please do this via PayPal to [email protected]
View attachment nuArchitectV4css.zip
View attachment nuArchitectV4js.zip
View attachment nuArchitectV4img6.zip
View attachment nuArchitectV4img5.zip
View attachment nuArchitectV4img4.zip
View attachment nuArchitectV4img3.zip
View attachment nuArchitectV4img2.zip
View attachment nuArchitectV4img1.zip
View attachment nuArchitectV4html.zip
View attachment nuArchitectV4LS.zip
View attachment nuArchitectV4dat.zip
Installation:
The files from the file nuArchitectV4LS.zip should be placed in your LW-Pluginpath
Than create a Folder (no matter where, no matter how you Name it) Lets say "nuSoft".
Create a subfolder of this Folder and Name it "Help"
In this "Help" Folder create 3 Folders and Name them "css", "img" and "js"
All Files from nuArchitectV4css.zip (there is only 1) should be placed in the Folder "css"
All files from nuArchitectV4js.zip (there is only 1) should be placed in the Folder "js"
All files from the files nuArchitectV4img1.zip - nuArchitectV4img6.zip should be placed in the Folder "img"
All files from the nuArchitectV4html.zip should be placed in the Folder "Help"
All files from nuArchitectV4dat.zip should be placed in the "nuSoft" Folder (the first Folder you have created)
Restart Modeler
Start any of the geometry creating script and Change to the "preferences" tab
Define the path you want nuArchitect to use
Define the Surface attributes you want nuArchitect to use at cretion
Click "Store"
Now you are done.
More Information on installing this bündle can be fount in the older threads of nuArchitect bündle.
A word to the scripts:
nuArches is to create arches
nuArchStones is to create arches build of single Stones
nuBridgeStones is to create bridges made of single Stones
nuCathCei is to create cathedral like ceilings
nuCirclePlan is to create Stone circles (like old fountains)
nuColumns is to create columns with many Options
nuDoors is to create doors with hinges, handles, peepholes and peepholedoors
nuFences is to create fences
nuFloors is to create floors
nuGates is to create gates
nuGothBlk is to create blocks in gothic style to use them als parts of a wall
nuGothXPass is to create gothic X-passes
nuGroundPlan is to create Stone pathes that can act as a ground plan
nuOrnaments is to create ornaments
nuPedestals is to create pedestals
nuPlaque is to create Plaques
nuRoofGable is to create Roof gables made of single Stones
nuRopePath is to create hanging ropes and chains
nuRopes is to create ropes and chains that follow a given path
nuRota is to create rotational objects
nuSockets is to create sockets like for a Memorial
nuStairStones is to create stairs made of single Stones
nuTombstone is to create tombstones
nuWalls is to create walls
nuWallStones is to create walls made of single Stones with arches, Windows and passes
nuWinsGoth is to create Windows Roman and gothic
nuWinsStd is to create Standard Windows
NameRequest is used by some scripts to request for a Name
YesNoRequest is used by some scripts to request yes/no answers
nuDefaultColor can be used to Change the Default Surface with 1 click (if you bind it to a button or menu) to that, define in nuArchitect
nuUV2TGA is to store a UV-Map as TGA file (the UV-Map must be in the foreground layer(s) to work correct) to do so, select the UV-Map you want to store and enter the path you want it to be stored
nuSoftLib acts as a function library and is used from nearly every nuArchitect script
If you using the old Version, you should remove this old Version or you can overwrite the old Versions of the scripts.
There are no new names to the scripts, so they will collide.
I hope you enjoy
Regards,
KANUSO
3dworks
archvizmacwaver
hi karl, thank you for this update - very appreciated! is it 2018 compatible? i will for sure send you a donation if i will ever use it for a commercial project! :D
KANUSO
Hi Markus,
yes, all scripts running well on 2018. The issues on some scripts in the older Version were fixed. The things which made Problems (boolean and axisdrill/soliddrill) were fixed from the LW gods too in the 2018.0.2 release. 2018 is one of the reasons why I did work on every script. The not so lucky choose of the dark Default Surface material with this megabrillant reflection did inspire me to implement the part on the preferences tab on every part of the bündle. You will even notice, that the geometry creating scripts are ca 60KB smaller each. This is because many of the work is now in the nuSoftLib and not in every script embeded.
Regards,
KANUSO
omichon
Thanks a lot for sharing these scripts. As said 3dworks, be sure I will send you a donation if any of these will ever be used in one of my projects.
paulhart
Animated Fool
I am very interested in this, and sadly, this is the first time that I paid attention in the forum to this posting.
I am always happy to donate to Open Source development, when I find something useful. This qualifies, however, I did some research and can't find your website or how to donate. It should be included in the bottom of your postings, this may account for the lack of feedback/donations.
Besides that, I got a little bit confused on the installation, got everything in folders, but could not locate the . . . went back in, Scanned the Plugins, then added them all to a Menu. Now I see the Preferences that you were referencing.
So, where to I put my money, because this was a lot of valuable work. I will try to say something else, after I play around with it.
KANUSO
Hi paulhart,
you are right, the Installation is a bit confusing. I will try to Change this in the future. I think about a small piece of Software for this Job.
If you want to donate, so please do this via PayPal to [email protected]
You can click on one of the 2 logos in any of the geometry generating scripts requester, there you will find this Information too.
On my Website you do not find any Information about These scripts. This will maybe Change in the future. The web can be found at www.nusoft.de but as sayed, there is no Information about nuArchitect and the website is in german language.
Regards,
KANUSO
