Normal Maps Plugin
DonLao
Does anyone know if the free normal maps plugin work in LW9.6, or does LW9.6 has those capabilities built in? Its website stated that the NormalShader.P doesn't work properly and recommend replacing it with TBshader.p instead. What about the 64bit, do I have to replace NormalShader.p with TBshader as it stated on its website? Does TBshader.p work in LW 64bit version though?
Any suggestions would be greatly appreciated!
nikfaulkner
mucho mojo
"with some adjustments, NormalCast can also be used to bake displacementmaps."
anybody any pointers on this?
ta
n.
Cageman
Almost newbie
ta
n.
Spirosa helped me with figuring out how to do it, so HUGE kudos to him! :)
See the attached screenshot on how to set up the additional nodes needed and consult the instructions at DPs site on how to set things up regarding NormalCast node and the lowres object as well as camera.
The UV-map assigned in NormalCast node is not needed (to avoid any confusion). You also have to concider that using this method will not generate as good results as if you were exporting a displacementmap from any of those sculptingtools, however, in many cases it might be sufficient enough for the project.
The main reason we did it this way was because Z-Brush managed to screw up the UVs, so whatever we exported looked funky. Finaly, I consulted Magnus (Spirosa) to see if he had an idea on how to bake a displacementmap from a highres (in this case a polydense export from ZBrush) object. And this is the resulting setup for the baking.
The result can be viewed here!
Credits: Radek Jakubiak (modeling, sculpting, texturing, shading, rendering and particles), me (rigging, animation and general problemsolving).
