Node never gets pas init
bpritchard
Morning all,
I'm working on setting up 6 machines in a small farm for some quick rendering and one of my nodes never gets past the "init" phase once screamernet is launched on it. I'm using the bat file method, and its exactly the same for all machines save the job and ack #'s. Any clue or info as to why it might get stuck on that? Its not erroring or anything and it never connects back to the host.
Cheers
Bryan
zapper1998
Michael Nicholson
Make sure all folders are seen on the network from the one node you are having trouble with..,its tryng to get the info from the Main Machine..
start main machine and start the node you having problems with.. and make sure all the nodes are numbered correcly.. two nodes with the same designation will cause a problem..
more than likely its not seeing the command folder..
double check the paths in the bat file, a single typo will do it..
done it a few times myself..
bpritchard
And there it was... freaking typo. :) Thanks for being captain obvious on that... i apparently keep forgetting to recheck the little things. Appreciate it!
Cheers
Bryan
jeric_synergy
Axes grinder- Dongle #99
IIRC matt has a routine (lscript?) that will set the nodes up for your. With zero typos.
(maybe I'm hallucinating.... quite a fever I got here.....)
