Nodal motion editor - simulating bounce/sway with bones
Iaian7
Motion Design Lead
I'm delving into some vector/rotational math with the Nodal Motion editor, and it's getting a little out of hand. :D
I'm working on a solution that will allow a string of bones to behave like a free standing spring. Reacting to parental motion with delay, decay, and counter-motion, but not following an actual motion path (they should retain basic skeleton shape, not act like a scarf) and not simply delayed in time (which relies on existing bone animation, not the inertia of the parental motion).
Probably the easiest practical example would be a bunny ear: it should bounce and sway with every twitch of the head and jump of the body, without having to hand animate what should otherwise be a very simple pseudo-physics simulation. The ears wouldn't even need to twist in this case, just bend left/right/up/down in reaction to their own physical inertia. Using nodes that add back any existing bone animation, you could even hand animate the ears and let the nodes add procedural bounce on top of the existing keyframe animation. Best of both procedural and directed worlds.
Using the DPkit Item Info node, I've derived the relative motion of the bone (subtracting world position -0.05 seconds in the past from the current world position) to give the inertia strength and direction (strength would be distance from zero, direction would be calculated from that as a vector, right?), and used that to...maybe...sorta...get some rotational values. Of course, because the bone orientation could be completely changed, the position offset or inertia direction has to be rotated into the world orientation of the bone itself (I think?). This can then be modified and added back into the existing keyframed data (the beauty of the Nodal Motion editor is that this is incredibly easy, unlike the other modifier effects available in the motion panel which are completely inflexible and overwrite the data instead of adding to it).
Screen Shot 2012-10-17 at 8.26.58 PM.pngScreen Shot 2012-10-17 at 8.27.32 PM.png
Anyway...I actually got pretty far! My bone setup reacts in realtime (start playing through the timeline and drag the whole object around to check it out!) with a sort of faked bounce animation (using three node trees with time delay and decay manually added to each - and yes, values were chosen for artistic reasons, not physical accuracy :hey:). I've attached a couple screenshots of my results, along with the Lightwave scene file and sample object. It appears to be 90% of the way there - it bounces, the child bones are delayed more than the parent bones, and it works in any parental orientation. However, I arrived at this point, quite literally, by just randomly trying stuff till it seemed to work. I have no idea what I'm doing here, and there are a few oddities in how it works from time to time. :devil:
View attachment BouncyBones.zip
My questions:
  1. Have I overlooked a better, simpler, easier solution? (motion modifiers like Follower obviously won't work, and effects like LazyPoints are uselessly awful and/or completely uncontrollable - ultimately whatever solution I find will be used to add secondary motion to a character with motion capture data driving all the primary motion)
    [*]What is the correct method for calculating local-based bone rotation using world-based inertia direction and strength?
    [*]Is there any way to actually/automatically calculate dampened spring-like motion without resorting to manually creating iterations in the node tree?
    [*]Could this all be done in Python? (I'm completely unfamiliar with it and unable to hack it together myself, but seems like a possible ideal solution)
Thanks for any/all feedback!
(except for "your math is ludicrously wrong" - I'm already fairly sure of that :thumbsup:)
SplineGod
Thanks! Should be interesting to look at. Ive done similar things in the past using bones along the throat of a creature to simulate the wobble on the fleshy parts. I remember using relativity to do it.
munky
Registered boozer
Sorry to burst in but I would just like to say that it's great to see you back Larry.
regards
Paul
Iaian7
Motion Design Lead
Absolutely, great to see you back Larry! :)
I hadn't looked into using Relativity, but I'm not seeing an easily applicable solution in the documentation. Hrm.
RebelHill
Goes bump in the night
I'll have to take a more thorough peek later... but yeah, there's a LOT of unnecessary stuff in there. maint hings you'll want to look at losing are the transpose matrix nodes (wpos IS the transpose of pos, and vice versa ofc)... You'll also wanna ditch those transform nodes... I suspect you've totally misunderstodd their usage. They are for applying simple linear transforms, most usually you'd be doing such to geometry... which is what they're really intended for... transforming a whole SET of vectors (as in vertices).
Otherwise, Im not sure how possible what you're after is gonna be... getting the "lag" motion... no problem... its the "wobble" that's gonna be hard. My first guess would be to take a sine function, to oscillate the motion on the bones, modified to turn in the needed direction vector. it may then be possible to sue a value decay finction to fade out the effect of the sine with respect to the motion that the ears are looking at to take their lag...
Ok, now Im waffling.
