NewBlue Titler Live Tricaster Macro Support
choffman
Hello.
Doe NewBlue Titler Live 4 allow for macros to control the Tricaster or is it only that the Tricaster macros can control Titler Live? I would like my worker who is running Titler Live 4 to bring up a background video (buffer) from the Tricaster while the titles are put live over it from Titler Live. I am tyring to reduce the work of the technical director on the main switcher.
Thank you.
Chris
410 AE Edition
fgolman
Chris, drop me a line as, I've got some experience with New Blue and macros.
The short answer, as far as I know, is TriCaster controls New Blue and not the other way. But I've got a great workaround for you.
Fritz Golman
PS, You're here in Chicago, right?
would love to hear what your solution is. I use Macros on the TC1 to control Titler Live 4 for my replays to pull graphics on and off and then a few others. In my case I am overloading the TD since I don't have a graphics operator :p
fgolman
So, basically, any workstation on your network can push commands and fire macros on the TriCaster with a http post command. You can use CURL command line processor.
For example, I have a function that starts running a DDR from another computer by using this:
CURL http://10.1.10.52/v1/shortcut?name=main_auto
I've actually incorporated it into a batch file so that it waits for a specific time of day to do this.
This actually executes an auto as if it were clicked on the control surface, where I have a DDR clip prepositioned in preview. Basically, any command or macro you can execute you can trigger this way, from the machine that's running the NewBlue Titler.
I believe this is outlined in the automation guide but really not explained in detail.
Fritz Golman
Ah very cool, will have to take a look. Hopefully my web password I set is in front of that don't need random folks joining in with the TD ;-)
kanep
NewTek SE
Here is a free tool that is a bit more graphical for a button controller. The author of this wrote this tool for vMix, but it was easy getting it working with TriCaster. If you have LivePanel you don't need this as it can do all of this and more, but this will give you 9 basic buttons you can click on.
Download and install: http://usbroadcast.co/httpmatrix.htm
Then download my HTTP Matrix configuration file for TriCaster use. View attachment defaultconfig.txt
Now go into the folder and replace the 'defaultconfig.txt' with my file above. You will need to do a few last things just to customize it to your needs.
Open the 'defaultconfig.txt' file in a text editor (like Notepad or Visual Studio Code). You will see a bunch of lines that look like below.
Code:
Macro 1
http://192.168.1.136/v1/trigger?name=Macro1
None
None
The first line is the name of the button, change it to what you want.
The second line needs the IP address "192.168.1.136" changed to the IP of your TriCaster system, leave everything else on the line alone.
Leave the last two lines as None.
Then save your updated file and run HTTP Matrix.
Finally, to make this run TriCaster's macros. Create your macro, then click on the trigger for the macro, finally click on the button in HTTP Matrix. You should see a trigger named something like 'net:macro#' appear as the trigger name. Pressing the button again in HTTP Matrix will get it to run the macro.
You do need the LivePanel password turned off on a TC1/VMC1 for this to work. With Advanced Edition systems don't need anything done to make this work.
dustinkVADJJ
Fritz Golman
Any chance could you help me out with this. I cant seem to get my tricaster to control New Blue at all.
dhomas
software developer
We recently have added support for New Blue Titler in Master Control. The API unfortunately is very complex and cumbersome. So we wrote our own direct control for it for our solutions. Similiarily, the process of getting Titler to control TriCaster is also a bit convoluted - particularly if you're not a developer. We create much simpler solutions for these kinds of things all the time, feel free to reach out to us if you need integration of anything with anything.
