NDI leaks windows HANDLE?
chiyuwang
I downloaded NDI SDK of version 4.6.1.
Also downloaded "Process Explorer", to trace memory usage, CPU etc.
Compiler is Visual Studio 2017 community
So I opened a c++ example "NDIlib_Send_Video" and modified it, so that the example can repeatly do the same thing over and over again and see if there is any leakage.
If check its handle usage from process explorer, you will see the numbers of handles increases with larger and larger value, and it never goes back. So I suspected that NDI is leaking handles.
Also if use "Application Verifier" from Microsoft, and enabled all items in basics, run the following code with Visual Studio Debugger, you will get access violation, I am not sure if the error is accurate though, but it is very suspicious.
Any reply is appriciated!!
Following is my modified c++ code.
C++:
#include <cstdio>
#include <cstdlib>
#include <cstring>
#include <chrono>
#include <Processing.NDI.Lib.h>
#ifdef _WIN32
#ifdef _WIN64
#pragma comment(lib, "Processing.NDI.Lib.x64.lib")
#else // _WIN64
#pragma comment(lib, "Processing.NDI.Lib.x86.lib")
#endif // _WIN64
#endif // _WIN32
int main(int argc, char* argv[])
    // To run forever
    while (true) {
        //Not required, but "correct" (see the SDK documentation.
            if (!NDIlib_initialize()) return 0;
        //We create the NDI sender
            NDIlib_send_instance_t pNDI_send = NDIlib_send_create();
        if (!pNDI_send) return 0;
        //We are going to create a 1920x1080 interlaced frame at 29.97Hz.
            NDIlib_video_frame_v2_t NDI_video_frame;
        NDI_video_frame.xres = 1920;
        NDI_video_frame.yres = 1080;
        NDI_video_frame.FourCC = NDIlib_FourCC_type_BGRX;
        NDI_video_frame.p_data = (uint8_t*)malloc(NDI_video_frame.xres * NDI_video_frame.yres * 4);
        //Run for one minute
            using namespace std::chrono;
        for (const auto start = high_resolution_clock::now(); high_resolution_clock::now() - start < seconds(10)/*changed to 10 seconds instead of minutes*/;)
        {    // Get the current time
            const auto start_send = high_resolution_clock::now();
            //Send 200 frames
                for (int idx = 200; idx; idx--)
                {    // Fill in the buffer. It is likely that you would do something much smarter than this.
                    memset((void*)NDI_video_frame.p_data, (idx & 1) ? 255 : 0, NDI_video_frame.xres * NDI_video_frame.yres * 4);
                    //We now submit the frame.Note that this call will be clocked so that we end up submitting at exactly 29.97fps.
                        NDIlib_send_send_video_v2(pNDI_send, &NDI_video_frame);
            //Just display something helpful
                printf("200 frames sent, at %1.2ffps\n", 200.0f / duration_cast<duration<float>>(high_resolution_clock::now() - start_send).count());
        //Free the video frame
            free(NDI_video_frame.p_data);
            //Destroy the NDI sender
            NDIlib_send_destroy(pNDI_send);
            //Not required, but nice
            NDIlib_destroy();
    // Success
    return 0;
roddyp
What's the rate of leakage? Does it change if you move the NDIlib init/destroy outside the loop?
chiyuwang
Thanks for your reply.
It leaks around 90 handles per 10 minutes when NDIlib init/destroy is outside the loop.
Almost 100 handles leaked per 10 minutes when NDIlib init/destroy is inside.
They are slightly different
