NDI bridge on private network
Not shown
Hello, I'm looking for an answer on the NDI bridge product. The NDI bridge tool works fine in a simple scenario over the Internet, but I am trying to use it on a private wide area network where the public Internet address is irrelevant, all NDI traffic will stay on our private WAN. I have internal NAT'd routers on our VPN between sites,so the actual IP I need to specify is different than what the software is detecting as the public IP (there is an Internet gateway as well). Is there a way to override that field and put in my private IP addresses as needed?
kanep
NewTek SE
You can't change your Public IP, it displayed for convivence. Enter the private IP on the JOIN side with the port you have configured, and it will connect.
Not shown
Thank you @kanep , I will try again and ignore the public IP,, although our intial testing it did not seem to work. I will post my results here once we have set it up again in case anyone else is also trying to do this.
