NC1 IO Windows Update Crashing Problems
MaxMattingly
Hi there, lately Newtek Connect on our NC1IO unit has been crashing to desktop every time we select a different input or output in the software with the little gear icon, among other similar issues. Here's the thing about the crash, though - it doesn't ACTUALLY crash, just disappears from view and I have to end task in Task Manager to be able to reopen it. It's pretty consistently reproducible, and also makes working with the unit a nightmare. I think it happened after installing a Windows update (that we were forced to install). Anybody else seeing this? Any ideas on how we can fix it?
Thanks.
lukerctv
Same thing has been happening here. Customer Service shipped me a new unit and asked me to RMA the old one. I suspect a hardware issue with the first revisions?
Still waiting for the replacement unit to arrive, I'll report back if the issue is gone.
lukerctv
I caught that little tidbit of info in another thread, and tried installing that older driver. Seemed to install fine, but the problem didn't go away.
Should I be doing anything to my replacement unit to make sure the same thing doesn't happen?
kanep
NewTek SE
Your not enabling automatic updates on Windows 10 with this option, because they are enabled already. What you are enabling is more control over the updates.
On my systems I have selected option '2' from the 'Configure automatic updating' drop down (I believe the default is selection 4). This will 'Notify for download and notify for install'. Now I get the option to prevent anything from downloading or installing right at the start. If I get a pop up window telling me that updates are available, just press 'ESC' to clear it and nothing happens.
mfassett
Ugh! I'm having the same trouble, my NC1 is a paperweight right now. Installing the older graphic drivers made the crashing happen less, but also made my newtek PTZ camera no longer work with the NC1.
Stuck!!!!
kelbyadmin
I've recently run into this issue as well. After recent Windows updates our feeds connected to Inputs 1-4 would show a black screen. I ended up uninstalling Windows updates and that resolved the issue. At some point, those updates will want to run again. I'll take a look at kanep's suggestion to gain more control over the updates. Thanks for the suggestion.
