Making a scene that is backwards go forwards
jamestownhodag
Editing is my life...ugh.
I recently had a reel of film that was not rewound correctly. I tried to correct it and the film is too brittle to run the correct way (wound the wrong way too many years on the reel) so I ended up transfering it upsidedown and backward.I was able to flip the video, but it is still running in reverse. Is there a way on SE 1.5 to make it play forward? To flip the film, I went into the control tree and found the way to flip it from upside down to right side up, but it is still in reverse. Thanks.
Scott Bates
Just Tryin' To Help...
F8 = Clip Properties. Select the clip and click the little button beside "Reverse" - been exactly there more than once....
lcress
Lynn Cress
However, if you have an affect such as a fade in / fade out on the beginning and end of the clip then your incoming video and outgoing video go in reverse.
If the clip is not too long, its a good idea to render your reverse clip out to a file and bring it back in to replace the original. That makes it a lot easier to deal with if you want to do fades, speed change, etc.
