LWS file format comment
ernpchan
Active member
I'm not sure you can as Layout will read those lines and try to process them. You could get around this by making a Master plugin/script that lets you save text to itself that then saves to the scene. The text is then saved within the plugin/script entry in the lws file.
dulo
Old Hog
I am parsing the lws file to create some passes I need for rendering. For one special task, I would like to mark a section in the scene file with a comment to easier find it while parsing . .
ernpchan
Active member
Not sure that's possible. Layout would have to know what to ignore when loading it. The render pass managers I've seen people make are done within Layout, not from parsing the file in a text editor.
darkChief
You could try inserting your own block (using braces and an identifying tag), I think the file resembles xml, Lightwave ignores tags/sections it's not told to explicitly load (by a plugin for example). May work.
jeric_synergy
Axes grinder- Dongle #99
That would be a 1) a very good thing to know (if #6 works), and 2) a very good Feature Request.
The OP might be able to delineate a section by using two CONSPICUOUSLY named nulls, depending on what he/she is trying to highlight. Legit comments would be better fer shure, but you do what you can.
darkChief
Also if you look at file io section of the c SDK documentation, at the bottom there's an example of inserting a custom section in text mode, to a LWS file,(can be anything), they use timezones as an example.
dulo
Old Hog
Thanks for the tip. will take a look into the SDK documentation.
dulo
Old Hog
I tried to use object comments ( eg displaycomment plugin ) but he always moves the comments to the top of the object definition or at the head of the scene file after saving.
// comment
jwiede
Electron wrangler
// comment
I believe the short answer is: Even if you could add comments, Layout's continual re-ordering and modification of LWS sections would effectively randomize their position and order.
LW Layout "owns" the overall structure/ordering of the LWS file, and rewrites it as scene changes occur. Plugins cannot rely on ANY placement/ordering to be maintained outside of sections they explicitly own. They only own the ordering/structure within their sections, that's it. They don't even own the relative ordering of their sections within the greater LWS file "whole".
