LW Camera to Apple Motion Camera
hemmster
Tried to make a Camera exporter for Apple motion. I'm nearly there but the orientation is a bit out. Is there anyone out there that would like to pick this up and finish off?
generic
valueMultiplier = 100;
//camera = Camera();
scene = Scene();
numOfFrames = scene.frameend;
fps = scene.fps;
reqbegin("Select Object");
c1 = ctlallitems("From Object");
return if !reqpost();
objectf = c1.value;
motionTimeMultiplier = 6144;
fileName = objectf.name + ".motn";
file = File(fileName,"w") || error("Couldn't open output file!");
//start of motion file
file.writeln("<?xml version="1.0" encoding="UTF-8"?>");
file.writeln("<!DOCTYPE ozxmlscene>");
file.writeln("<ozml version="5.8">");
file.writeln("<factory id="1" uuid="7d468273c013498e9806a0d7bc32fddf">");
file.writeln("<description>Project</description>");
file.writeln("<manufacturer>Apple</manufacturer>");
file.writeln("<version>1</version>");
file.writeln("</factory>");
file.writeln("<factory id="2" uuid="de1a9415beb34e5fb0964d1528bef14a">");
file.writeln("<description>Camera</description>");
file.writeln("<scene>");
file.writeln("<sceneSettings>");
file.writeln("<width>1920</width>");
file.writeln("<height>1080</height>");
file.writeln("<duration>120</duration>");
file.writeln("<shouldOverrideFCDuration>0</shouldOverrideFCDuration>");
file.writeln("<frameRate>25</frameRate>");
file.writeln("<NTSC>0</NTSC>");
file.writeln("<channels>4</channels>");
file.writeln("<pixelAspectRatio>1</pixelAspectRatio>");
file.writeln("<workingGamut>0</workingGamut>");
file.writeln("<viewGamut>-1</viewGamut>");
file.writeln("<backgroundColor red="0" green="0" blue="0" alpha="1"/>");
file.writeln("<audioChannels>2</audioChannels>");
file.writeln("<audioBitsPerSample>32</audioBitsPerSample>");
file.writeln("<fieldRenderingMode>0</fieldRenderingMode>");
file.writeln("<motionBlurSamples>8</motionBlurSamples>");
file.writeln("<motionBlurDuration>0.5</motionBlurDuration>");
file.writeln("<sharpScaling>0</sharpScaling>");
file.writeln("<startTimecode>0</startTimecode>");
file.writeln("<presetPath>/Users/pete/Library/Application Support/Motion/Presets/Project/1080p.preset</presetPath>");
file.writeln("<backgroundMode>0</backgroundMode>");
file.writeln("<reflectionRecursionLimit>2</reflectionRecursionLimit>");
file.writeln("<glyphOSCMode>0</glyphOSCMode>");
file.writeln("<animateFlag>0</animateFlag>");
file.writeln("<parameterColorSpaceID>3</parameterColorSpaceID>");
file.writeln("<savePreviewMovie>0</savePreviewMovie>");
file.writeln("</sceneSettings>");
file.writeln("<currentFrame>6144 153600 1 0</currentFrame>");
file.writeln("<timeRange offset="0 1 1 0" duration="737280 153600 1 0"/>");
file.writeln("<playRange offset="0 1 1 0" duration="737280 153600 1 0"/>");
file.writeln("<flags>1</flags>");
file.writeln("<audioTracks>0</audioTracks>");
file.writeln("<timemarkerset/>");
file.writeln("<guideset/>");
file.writeln("<curvesets selected="1"/>");
file.writeln("<scenenode name="Project" id="3000000358" factoryID="1" version="5">");
file.writeln("<flags>0</flags>");
file.writeln("<timing in="0 1 1 0" out="-6144 153600 1 0" offset="0 1 1 0"/>");
file.writeln("<foldFlags>0</foldFlags>");
file.writeln("<baseFlags>16</baseFlags>");
file.writeln("<parameter name="Properties" id="1" flags="8589938704"/>");
file.writeln("<parameter name="Object" id="2" flags="8589938704"/>");
file.writeln("</scenenode>");
file.writeln("<scenenode name="Camera" id="3000000361" factoryID="2" version="5">");
file.writeln("<aspectRatio>1</aspectRatio>");
file.writeln("<timing in="0 1 1 0" out="731136 153600 1 0" offset="0 1 1 0"/>");
file.writeln("<baseFlags>17</baseFlags>");
file.writeln("<parameter name="Properties" id="1" flags="8589938704">");
file.writeln("<parameter name="Transform" id="100" flags="8589938704">");
file.writeln("<parameter name="Position" id="101" flags="8589938704">");
file.writeln("<foldFlags>11</foldFlags>");
//custom stuff here
//channel x POSITION
file.writeln("<parameter name="X" id="1" flags="8606711824">");
file.writeln("<curve type="1" default="0" value="0">");
file.writeln("<numberOfKeypoints>" + numOfFrames + "</numberOfKeypoints>");
for(i = 0; i <= numOfFrames; i++)
time = i / fps;
file.writeln("<keypoint interpolation="1" flags="0">");
file.writeln("<time>" + (i * motionTimeMultiplier) + " 153600 1 0</time>");
vec = objectf.getWorldPosition(time);
val = vec.x;
file.writeln("<value>" + (valueMultiplier * val) + "</value>");
file.writeln("</keypoint>");
file.writeln("</curve>");
file.writeln("</parameter>");
//channel y POSITION
file.writeln("<parameter name="Y" id="2" flags="8606711824">");
time = i / fps;
val = vec.y;
//channel z POSITION
file.writeln("<parameter name="Z" id="3" flags="8606711824">");
time = i / fps;
val = vec.z;
file.writeln("");
//rotation
file.writeln("<parameter name="Rotation" id="109" flags="8589938704">");
//loop through rotation x
time = i / fps;
vec = objectf.getWorldRotation(time);
val = vec.y / 57.2957795130823;
file.writeln("<value>" + val + "</value>");
//loop through ROTATION y
//loop through keyframes
time = i / fps;
val = vec.x / 57.2957795130823;
//loop through ROTATION z
time = i / fps;
val = vec.z / 57.2957795130823;
file.writeln("");
//finish the motion file
file.writeln("<parameter name="Object" id="2" flags="8589938704">");
file.writeln("<parameter name="Camera Type" id="200" flags="8606777360" default="1" value="0"/>");
file.writeln("<parameter name="Far Plane" id="203" flags="8606711808" default="10000" value="12317.645019878171"/>");
file.writeln("</scene>");
file.writeln("</ozml>");
file.close();
info("Done");
