LW B747 Benchmark (LW 2020+)
KeystoneMike
LW Oldtimer
Intel i7-6900K, 64GB (8core/16thread)
Non volumetric: 26m 17s
Volumetrics: 1h 32m 11s
I really really want the 3970X now!
Threadripper 3970x, no OC, LightWave3D v2020.0.1
LW_B747_Bench : 4 min 32s
LW_B747_Bench_Volumetric : 15 min 15s
ciao
Thomas
what’s the system details there?
AMD Ryzen TR 3970X Threadripper
ASRock TRX40 Creator
G.Skill RipJaws DIMM 64GB, DDR4-3200
CPU cooler: be quiet! Dark Rock Pro 4 TR4
Gigabyte Aorus NVMe Gen4 SSD M.2
GeForce RTX 2080 Ti
tower: be quiet! Dark Base 900
PU: be quiet! Dark Power Pro 11 1000W ATX
ciao
Thomas
allabulle
Active member
LW 2020.0.1
i7-5960X OC to 4.2GHz
LW_B747_Bench.lws 22m 11s
LW_B747_Bench_Volumetric.lws 1h 14m 03s
raymondtrace
Founding member
There are some issues with my benchmark test so don't assume any accuracy. I've unintentionally tarnished the reputation of 3950X. :)
The CPU shows 3.89 GHz as reported during rendering. However, it can be turned up to 4.7. I also just noticed that the mfg shipped me slower RAM than what I ordered. This is on 2400 MHz RAM.
Qexit
Active member
Nothing too wonderful on my system:
LW_B747_Bench.lws 11m 0s
LW_B747_Bench_Volumetric.lws 37m 36s
Dell Precision 7810
LW 2020.0.1
Windows 10 Pro Version 1903
Dual Xeon E5-2680 v3 @ 2.5GHz
64GB DDR4 ECC 2133 MHz
GPU 8GB RTX 2080
Room Temp= 27 Degrees C :)
Tim Parsons
Well-known member
Also I think if we are adding specs to the boxes we used to render these, we should also add how much was spent on the boxes. :)
Mine was $1100 USD.
Qexit
Active member
Mine was $1100 USD.
Fair enough. My Dell Precision 7810 cost me £420 GBP back in early March. I upgraded the graphics card to an RTX 2080 later in the month for an additional £450 GBP, the rest of the spec is unchanged. :)
Rayek
Well-known member
LW_B747_Bench.lws render time: 32m34s
i7 [email protected], 48gb ram. GTX 1080 8GB
Slooooowwww. Not surprising for a 12 year old system! I am planning to update soon: either a 3950 or 3960.
I did not bother rendering the volumetric version.
Because I was bored this afternoon (and frustrated at these slow render times) I converted this scene for rendering in eCycles for fun.
50 seconds for a comparable result. Much better.
Someone ought to render this scene in Octane in Lightwave as well. I do wonder why Layout gobbles up gigabytes of memory to render, while eCycles peaks at around 800mb. The scene data and textures are identical. Ah well, apples and pears, and such.
Still interesting to see how much faster GPU rendering can be - and a way to keep an old machine somewhat relevant for rendering.
I intend to get a 3000 Nvidia series card later this year or early next year after I purchase my new comp, which should get that render time down to 10 seconds or less in the RTX version of eCycles.
Good times ahead!
Lewis
Member # 777
Nice results guys, waiting for 3990X TR4 to smash us all at aroudn 3 minutes mark :).
allabulle
Active member
Oh, fine. I thought so, Lewis.
Maybe someone with such a machine can spare a minute to hit F9. It will probably take them more time to download and post the results than to actually render the scenes.
Didn't our fellow Lightwaver cageman had one of those monsters at hand? Let's see if he hops in.
gar26lw
GeForce RTX 2080 Ti
ciao
Thomas
i wonder why a bit faster?
kolby
4.7 GHz is the highest speed in a single core load. On all cores, it could be around 4.2 with good cooling. The problem on your part is probably the low memory frequency. My machine with a Dark Rock cooler and two fans in push/pull mode usually runs around 3.96 GHz on all cores.
rustythe1
www.Digitawn.co.uk
thats why using rainmeter / HWinfo is good as it can show you each individual core and details of each, makes a big widget for mine so you would probably need a whole screen for 64 threads! but some of the widgets out there are quite compact with a lot of info.
